  #26 (permalink)
Old 12-27-2018, 09:25 PM
CoyoteCobra CoyoteCobra is offline
Cobra Make, Engine: A&C, 2nd gen 5.0 Coyote, XAct Cromo light flywheel, TR3650, 3.25:1 LSD
I'm going to have to check out the Wilwood MC then. I have the 12" 4 piston Wilwood Dynalite on the front and a Summit single piston 11.25" disk setup on the rear. I'm not sure what diameter the pistons are in the rear so I'll have to check to see what MC will work with this config.
In hindsight I probably should have gotten the Wilwood in the rear to begin with. When I looked earlier I was searching for Dynalites for the 9", and I did not see one with a parking brake option. It looks like Wilwood does make a kit for the 9" that includes a parking brake but it uses a drum brake for the parking function.
