Originally Posted by saltshaker
I used A&C’s pedals and I think I drilled a hole to make 5 to 1..easy to do
Did you cut the hole for the pedal assembly?
Jon
Saltsaker, did you just drill a hole up higher on the pedal arm causing the pushrod to connect higher and increase the ratio?
I sent you a PM the other day asking some questions about your brake setup.
Thanks for you help! Trying to get my brakes to be where I want them.
