Thread: New Backdraft
  #21 (permalink)
Old 12-30-2018, 09:06 AM
bobcowan's Avatar
bobcowan bobcowan is offline
I'v been driving #1642 for only a few months. There are a couple of issues I'm working on.
Brake power booster was dead. Had to replace that immediately, before I could really drive it. Not overly expensive. But a real PITA to do.
Brakes are still not that great. With the booster working, they are OK. But I want better. I'm going to upgrade the pads this winter. Probably should have skipped the power brakes and went straight to Wilwoods.
The fuel level gauge is pretty erratic.
Some of the lights under the dash were not plugged in.
Steering shaft is weak. At first I thought something was loose. But if you turn the wheel and watch the shaft, you'll see the shaft and joints flex. The only answer is to replace the shaft and joints with something stronger.
People report engine and transmission problems. That's not a BDR problem. That's an installer problem.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
