Old 01-08-2019, 02:44 PM
Grubby's Avatar
Grubby Grubby is offline
Cobra Make, Engine: ERA 838
Does it grind going into reverse?
For trouble shifting into 5th, I agree adjusting the shifter and stops is pretty easy. If you Utube it will come up. I can give you the run down if you can't find it.
When the shifter is adjusted correctly let us know if it is fixed or if the shifter was even a problem.
5/R share the same shifting fork in that transmission. It could be a bent or damaged shift fork, but don't think about that yet.
I have never driven a car with a Doug Nash/Richmond. Can you shift quickly and hit all of the gears? I am very unimpressed with the TKOs for the 2/3 shift and am planning my next Cobra.
John
