Old 01-08-2019, 04:47 PM
Moriarty Moriarty is offline
Cobra Make, Engine: ERA 427sc
I have never driven a car with a Doug Nash/Richmond. Can you shift quickly and hit all of the gears?
1st is a bit sticky to get into. 2nd, 3rd, and 4th all seem fine. With 5th, I go over and up, release the clutch and am still in neutral. No grinding, just doesn't seem to find the gear. I have had some grinding trying to get into reverse, although most of the time it just acts like 5th does now - over and back, but doesn't engage. Wiggle around a bit and I can usually find it.
I would like to work through this process at some point. https://youtu.be/6UnFDaAdBaM
Are you using the Long shifter or a Hurst?
Unsure - long? It's bent forward like stock/originals.
Chris - thanks, I'll check that and also dig up the info in the manual.
