Old 06-05-2002, 07:09 AM
Geary L. Sarno Geary L. Sarno is offline
Cobra Make, Engine: Unique 427SC, 403 FE. Dual Quad
Default Idle Mixture
1 1/2 turns out from seat should get you started. The best way I've found to set up your idle mixture is to connect a hand held vacuum gauge to the full-time vacuum port. Adjust one idle mixture screw at a time until you get the highest vacuum setting and smoothest idle. Adjust the idle speed and recheck your mixtures. I'm running dual 1405's and have success with this method. - Aggressor
