Thread: Storage
Old 01-16-2019, 03:28 PM
Cobra #3170 Cobra #3170 is offline
I pull the plugs and squirt oil in each cylinder then spin on the starter to coat valves and cylinders with fresh oil. I then pull all the rockers to take pressure off valve springs and keep all valves on their seats to prevent any corrosion. reinstall plugs and put antifreeze in cooling system to protect the aluminum. Also remove wheels and store on jack stands as well as all the other normal stuff like fresh oil and filter and draining the fuel system. I have a disconnect switch on the battery so that seems to be enough to protect from discharge.
