  #155 (permalink)
Old 01-17-2019, 07:28 PM
otto otto is offline
Cobra Make, Engine: ERA 2092
I just reinstalled mine in 2092 went in from the side , bellhousing was attached to trans. I was able to leave the hood on, I left the motor mounts off till I had the block bolted to the bellhousing then slid the mounts in place. I agree you should do a dry run with your engine crane to make sure the boom is long enough. Hope this helps
