Originally Posted by my427cobra
Thanks CHANMADD. I will check that also. It could be possible it went out of adjustment (the top center link).
The problem has just manifested itself after perfect driving for years.
Greg
Possible bad shock, or one has worn more than the other. This would translate into more suspension travel on one side with throttle application, and with your suspension type that creates rear steer. Think about the geometry: if you push one side up, with parallel upper and lower links that are both parallel to the ground, the side being pushed up is effectively getting shorter, pulling the axle forward. This is what Jerry is talking about above... lots of crazy stuff going on that is hidden by springs and shocks, until something goes off.
