Old 02-07-2019, 02:34 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by xb-60 View Post
With respect to height, Autometer states "If not mounted level with each
other, the fluid weight will cause a slight accuracy error
They also say "Isolator must be mounted in engine compartment. (DO NOT mount on firewall per NHRA/IHRA rules.)"
I assume that not mounting on the firewall is to further isolate fuel from the driver.
Glen
It is a bit confusing.
Must be mounted in the engine compartment.
Of course we all know that's obvious.
Can't be mounted on the firewall.
But must be mounted at the same height as the gauge.
I'd give up on that idea, and go for something like this:
https://www.competitionsupplies.com/...pressure-gauge
I've seen many stepper motor gauges, accurate as you need, and only a tiny wiring harness to hide.
Gary
