Old 02-07-2019, 10:04 AM
cycleguy55's Avatar
Originally Posted by xb-60 View Post
With respect to height, Autometer states "If not mounted level with each
other, the fluid weight will cause a slight accuracy error
They also say "Isolator must be mounted in engine compartment. (DO NOT mount on firewall per NHRA/IHRA rules.)"
I assume that not mounting on the firewall is to further isolate fuel from the driver.
Glen
First, how much is a "slight accuracy error"? If it's 0.05 PSI it's not going to be an issue.
Second: I believe the NHRA/IHRA rules are about not mounting it on the passenger side of the firewall - the engine compartment side s/b fine.
Brian
