Old 02-12-2019, 12:49 PM
patrickt patrickt is offline
By the way, I remembered reading this guy's Jag rebuild blog and his page on setting the float for the outer fulcrum bearings. He writes that If you are installing new bearings, you should install more shims than necessary to get a large enough float to measure. Usually 0.010" - 0.020". See Step 20 It took me a while to find it (and I didn't want to quote it from memory). Here you go: https://relicrecyclery.com/Jaguar/page30/63XKE_30j.htm
