Originally Posted by deano59
how did you get a gps speedo passed thru engineering i didnt think there were allowed? but i can see why you would do it tho ..remind me again what auto box your using jaydee.
cheers dean
Originally Posted by Jaydee
In the engineering report it shows that the engineer used a GPS to calibrate speedos. So in the column of his reading and mine it showed no discrepancy. I guess everyone was happy.
My auto is a BTR 95 . Its not shifting into 4 and start in second unless I manual shift it into 1. And the torque convertor doesn't lock up. I think it must be in limp home mode. JD
Originally Posted by Gaz64
GPS speedo is illegal in Australia for any vehicle with ADR 18.
Gary
I still don't believe GPS speedo as the only source of speed indication is legal.
I'll post the documentation when I find it.
Your auto is probably in limp mode because the PCM is not seeing a speed signal, since the VSS is not hooked up.
Gary
