Old 02-14-2019, 05:42 PM
PeteF's Avatar
PeteF PeteF is offline
Cobra Make, Engine: ERA2041 sold 2021
There are also one or two vacuum ports in the carb base under the front bowl, not visible in your pictures. They provide full manifold vacuum when used. Make sure they are also capped if not used. I don't see a vacuum hose coming from that location, so I assume you are not using those ports.
