Old 02-18-2019, 04:54 PM
Frank Messina's Avatar
Frank Messina Frank Messina is offline
Cobra Make, Engine: FFR, V8, Manual Trans, Htr, Wipers, Radio Delete
That is a timed vacuum port that is not needed in your case since you are not running vacuum advance and should be capped off. It does nothing at idle but supplies vacuum when the throttle is opened or creates a vacuum leak if left uncapped. It was a bad idea attempt at emission control back in the '70s and should never be used.
Frank
FFR - V8, Manual Trans, PS, Inop Wipers, No Radio, Gas Mileage so-so
