Thread: 302 timing
Old 02-19-2019, 09:16 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Horseracejudge View Post
Hello Boatbroke,
Have similar occasional back fire through intake on a 302 HO, 303 cam, GT 40 upper & lower intake, 65 mm throttle body, GT 40 heads(GT 40 EFI Option Package). Timing at 12-13 degrees. I've heard the same complaint from others with this set up. It is inherent without better distribution of fuel air mix. Independent runners make all the difference. Nick
With EFI, you won't be having a mixture distribution issue like single carburettor engines can have.
So you need to look at lean areas of your fuel map.
Gary
