Old 02-27-2019, 09:30 AM
520SC's Avatar
520SC 520SC is offline
Cobra Make, Engine: 1966 Street Beasts Cobra 427 S/C, 502 cid
The symptom I had was a loud squeal, not grinding, so your problem may be different!
Sounds very different. My problem is definitely caused by gear teeth clashing resulting in progressively worsening damage.
BTW, is there anything behind the ring gear that the starter drive gear could make contact with after it is (too) fully engaged?
No.
Another thought: There are two different starter drive gears if my recall is accurate. One is for a flywheel and the other for a flexplate which - I think - have different numbers of teeth.
The one I've been ordering says that it's compatible with a 1974 Thunderbird 7.5L. Those all came with C6 3-speed automatic transmissions (which is what I'm using).
Todd
