Old 03-04-2019, 06:50 AM
Sawdust's Avatar
Sawdust Sawdust is offline
Aside from checking any fluid leaks I would definitely look at the tires (age) even if there is lots of tread the tires might be 7+ years old. Also ask if the current owner has done the rear upper shock mount upgrade. Check for maintenance records. Compression test on the engine.
Good luck!
