Originally Posted by Ron61
I use safety wire but I put mine on so it will loosen up if the spinner starts to back off. Then before and after each run I go around and tug on the safety wire a little to see if it is still tight. I don't depend on it to keep a spinner on so that is why I did mine backwards to what most people do.
The tug test should work either way. If you install it to tighten if the spinner loosens and the wire strums like a guitar string, the spinner loosened.
