Originally Posted by lomdel
Besides the QuickJack which has been widely discussed elsewhere in this forum, what other low- to mid-rise home garage car-lifts do you guys use? I have seen the Ezcarlift ( https://www.ezcarlift.com) and the Autolift3000 ( https://www.autoliftproduction.com) which both does not use any hydraulics. Not cheap though...
What other ones lift all four wheels off the ground that have a small footprint and is relatively affordable?
Check out some old service stations that are not using / looking to get rid of their old air over hydraulic lifts. Other than the ramps which you will need to drive the car on to, The lift only requires a 14 inch diameter hole in your garage floor about twelve or so feet deep.
You'll should immediately remember the lift when you see the man cave pic below.
Ed
