Originally Posted by Alfa02
Good thought ! I run a 275-60-15, where most other's here run the 295-50-15 rear's. Would that make my angle a touch different, maybe? Mine was zeroed out, on the cowl, then measured on the windscreen, so maybe not? I'm confused, which doesn't take to much, now-a-day's  ???
If you zeroed out on the cowl then you are measuring the angle with respect to the car. Ride height will not affect the angle.
Ride height only affects the angle if you measure with respect to horizontal or vertical, such as with a bubble level.
