Old 03-21-2019, 12:52 AM
razerwire razerwire is offline
Cobra Make, Engine: csx4163 full comp alu. body
Posted before but anyway FWIW. Had race deck and -1 how do you wipe up oil spill? you take the tiles back up and clean. -2 how do you stop the tiles from moving when you turn wheels when vehicle is not moving? you don't.-3 How do you stop big movement due to expansion and contraction? You don't. How I solved was put down ceramic tile. Now can stop and turn wheel on bus motorhome without floor moving. Spills wipe up easy. Got 12" tiles in Mexico for 50 cents apiece. Used half thickness of thin set to put down so weight of bus will not crack, it's working been down 8 years. Bus weights 50,000 lbs. Put 4 post lift right on top of tiles and no problems. Cut tiles around two post lift , mill, lathe. Rest of equipment goes on top of tile. Welding over floor just put down welding blanket. 2800 sq foot garage was $3000.00
