I went with RaceDeck diamond plate texture. I also installed it over landscape cloth. No clicking, but it does move around a bit, particularly when I pull into the garage and apply the brakes--there's enough momentum transferred to the flooring, and low enough friction from the landscape cloth, that it scrunches toward the front of the garage.
I'm not a fan of epoxy. I've seen too many fail even when prep was "perfect" (i.e. new construction, concrete etched, etc.) It looks beautiful when done, but it seems to have a high enough failure rate to pursue other options.
If you have the patience and skill (or connection with trades) heavy-duty ceramic tile would be tough to beat. I'm guessing it would be a bit more than SwissTrak or RaceDeck, but look better and be a bit easier to maintain.
