  #27 (permalink)
Old 03-25-2019, 12:06 PM
EZ$ EZ$ is offline
Cobra Make, Engine: Factory Five
Keep in mind, if you decide to do epoxy, prep is the most important piece of the puzzle. It determines 100% whether you have a successful installation, or not. Diamond grind, or find someone that does shot blasting, or some other dry blast. Avoid acid etching. You will never completely neutralize the acid, and it could come back to bite you on the a**! Also, just about zero tract homes will have a vapor barrier under the slab in a garage, but there are manufacturers of epoxies that have a moisture vapor resistant primer that you can use to overcome this issue. Other than that, ALL brands of 100% solids epoxy are virtually the same once cured. Just different characteristics when handling like pot life, etc. No reason to shy away from them.
Rick
