Mine works, its a Momo with slip ring and VW beetle turn signal with the high beam switch on the back of the lever. I made an insulation pad between the turn switch and the slip ring....to insulate it ..electrically..and it holds the ring from turning. The wire got a shrink wrap for strength and goes under the switch and through the dash to ....
If you already have a floor dimmer you can use this switch for a horn too.
