  #33 (permalink)
Old 03-26-2019, 06:53 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by EZ$ View Post
Vinyl Composition. But be careful, it has issues with moisture vapor transmission same as epoxy coatings do.
Good consideration. Chances are your original floor failed due to moisture coming up through the concrete floor. There probably isn't a vapor barrier under the floor, in which case any seal on the floor is doomed. Your choices in that case are to grind off the old failed sealer and leave it concrete or cover it with one of the vinyl puzzle tile covers like race deck. Any of the ones that leave a full sealed cover could cause further concrete damage.
Tony
CSX4005LA
