Old 03-29-2019, 09:43 AM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
Default Oil temp gauge installed
Just installed some new SpeedHut gauges. A new gauge I now have is oil temp. It is plugged into the side port on the Canton pan. I've noticed that when I'm driving the oil temp gauge is pegged cold, but when I stop, it will climb up to the correct temp. I'm thinking that since the pan is down in the air steam, the sensor is getting cooled by the passing air. Do I just need to insulate the sensor? Wrap it with heat shielding?
