Old 03-29-2019, 10:30 AM
cycleguy55's Avatar
Originally Posted by Texasdoc View Post
Just installed some new SpeedHut gauges. A new gauge I now have is oil temp. It is plugged into the side port on the Canton pan. I've noticed that when I'm driving the oil temp gauge is pegged cold, but when I stop, it will climb up to the correct temp. I'm thinking that since the pan is down in the air steam, the sensor is getting cooled by the passing air. Do I just need to insulate the sensor? Wrap it with heat shielding?
Your situation seems baffling to me.
I have a VDO temp gauge and sensor, and my readings don't vary whether I'm driving or stopped. As far as I know, the portion of the sender that actually takes the reading is inside the oil pan and not exposed to air flow.
Looking at the SpeedHut sender it looks like it would be totally immersed as well:
I suspect there's something else going on. Does the wire have a solid connection to the sender? Could it be moving around or grounding against something while the vehicle is in motion, but not when stopped? Looking at the impedance / temperature chart, zero impedance (e.g. grounded) would display cold on the gauge.
Brian
