  #468 (permalink)
Old 04-05-2019, 07:06 PM
1795's Avatar
1795 1795 is offline
Originally Posted by CompClassics View Post
It was great that you caught this perfect example of poor engineering and design prior to loosing a very expensive component. As I explained to the manufacturer "what good is it that the gear oil is in the catch can (not to mention the oil that spewed out from the catch can) while the differential is operating, doesn't the gear oil need to be in the differential to maintain the proper capacity for operation?" I find it even more negligent that the manufacturer of the differential had instructed the manufacturer of the vehicle how the differential venting system needed to be installed and the vehicle manufacturer neglected to follow the differential manufacturers directions. As the manufacturer explained to me "there is many ways to do something...", well I guess they proved how to do something........the wrong way.
John,
What is most disheartening is the lack of culpability. We all make mistakes or misjudgments, honor is in accepting responsibility and making amends.
I will say that just in case there was some differential oil making its way to the catch can, I had the inlet from the differential inserted into the bottom of the catch can so that fluid could return to the diff once pressure lessened.
Jim
