Great discussion on this subject. Thanks for all your input.
But, I'm still trying to determine the genesis of the aluminum hood scoop I have.
I have found many fiberglass hood scoops from numerous sources but they are an inch or two narrower than my scoop and quite a bit "squarer" at the back of the scoop while mine is somewhat tapered and more round at the back.
Not sure which are the "original" dimensions and shapes.
I also thought I had read somewhere that there were two widths of hood scoops for the 427 Cobra with the big 58mm Weber carbs using the wider scoop?
Greg
