Originally Posted by Jaydee
I wonder if you can fit a moisture trap before the compressor? JD
While it may be reduced by 'pre-condensing' and removing the water from the air before it hits the reservoir tank, I'm not convinced that would entirely solve the problem. As the water condenses upon contact with the cooler walls of the air tank you may still have further condensation.
