You might also want to look at the length of your brake pedal relative to length of the pivot for the master cylinder push rod.... Wilwood, for example, sells one brake pedal assembly with a 6.25:1 ratio and another at 5.1:1. Obviously the higher the ratio the less pressure you need to push on the pedal.
