Old 04-17-2019, 02:54 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by razerwire View Post
If it has a Chevy engine in it I'm confused. Is the engine mounted backwards because the distributor is towards the fan.
It has a front mounted distributor as a conversion to make it look like a Ford engine. A close up view on where a Chevy distributor normally goes shows a dummy drive shaft for the oil pump.
The valve covers are meant to look Fordish, but the Chevy header configuration is the first giveaway.
Gary
