Originally Posted by Late Apex
Im searching for a compact shift light for the column and have found numerous makes but many have bad reviews. I want one that does not require the RPM activated switch which is an additional purchase and more complex install. So far I like the MSD 89631 all in one unit but need your input for those that have a shift light before I buy one. Which model do you have or like? Pros and cons. Thanks
How will you mount the MSD 89631? Pic if already mounted please.
The Omex Shift Light Pro (
https://www.merlinmotorsport.co.uk/p...ight-pro-omslp ) might be the smallest, most discreet one I have seen. The small single 10mm round LED light can be incorporated in the dash to resemble a normal warning light...
