Old 05-04-2019, 05:16 PM
patrickt patrickt is offline
Originally Posted by Whodeeny View Post
My initial thought was the hose fittings also but now I don't think the leak is coming from the hose. It appears to me to be coming from the flange area where the gasket is or one of the bolt holes. The threads around the hose fittings are not wet with oil but the flange area is.
Bolt holes are notorious for leaking on a remote filter adaptor. Mine are loaded up with gasket sealant so that it is goo-ing out of all four bolts holes. But when I looked at the picture I thought it was leaking from the fitting too. If you wrap the fitting tight with a paper towel, and then run the engine for 30 seconds, and unwrap the paper towel, it should be dry as a bone. I have Teflon tape on the threads of both lines going in to my adaptor. Of course, using UV dye with a black light will tell you instantly exactly where the oil is coming out.
