Old 05-09-2019, 04:39 PM
cycleguy55's Avatar
Originally Posted by Gaz64 View Post
Just run a higher pressure cap on the lower point. Then at that point, cap the recovery tube.
The upper cap will then be always be the point of release into the recovery tank.
Only the upper cap needs to be removed to check your coolant level.
Gary
I have a 13 PSI cap on the upper point, and a 20 PSI on the lower. Do you feel that's sufficient pressure differential that I can safely cap the lower recovery tube?
Brian
