Old 05-12-2019, 08:30 PM
Whodeeny Whodeeny is offline
Cobra Make, Engine: ERA 427
Originally Posted by spdbrake View Post
Looking at your post it mentioned the ONLY light still functioning is the LEFT Front?
"I fixed it then went to recheck all my lights again to be sure everything else was still working only to discover that now the brake lights, the front and rear right signal lights and the left rear signal light no longer work
The 3-2 converter box appears to be a Buyer Products or Curt Mfg unit.
About $15-$25 most anywhere. Advance Autoparts, U-haul etc...
https://www.buyersproducts.com/produ...iteria=5423203
https://www.amazon.com/BUYERS-PRODUC...gateway&sr=8-1
https://www.delcity.net/curt?id=Towi...CABEgJ6M_D_BwE
Looking at the ERA wiring diagram page 15 the Pick-off for the front Turn and Parking lights occurs Before the Converter.
http://www.erareplicas.com/427man/wiring/wprimer.pdf
You didn't just convert to Led bulbs per chance? That can create the same scenario you are experiencing.
Yes, only the left front turn signal light is still working. No sir, I did not convert to LED bulbs.
From the other posts to this question it looks like I need to check the functionality of all four bulbs by feeding 12v to each filament. I will do this tomorrow and get back to you all. I will give Bob Putnam a call tomorrow too.
By the way, in the event that I do need to replace the 3-2 converter box, how is it removed from its mounting plate?
BD
