Old 05-14-2019, 07:44 AM
rbgray1's Avatar
rbgray1 rbgray1 is offline
Originally Posted by Pasta Power View Post
rbgray1, I did not think your question through and missing the brace part of your problem before sending my reply. I am familiar with that setup and this type of tank may not work. I have been running this configuration for 26 years without any problems if you decide to change yours. The contact info for the tank is "classicfordradiator.com" 516-293-2175. I will be happy to send more pics.
Pasta Power, thank you very much for the pics and follow-up recommendations. They will be very helpful.
Can you tell me what the distance is from the front of the Intake manifold tstat connection point to the forward most point of the 90 degree up bend in the expansion tank inlet tube? This dimension is critical as i need to clear the tension bracket for the alternator.
Your March system isn't the same as mine and doesn't have this tension bracket.
