Old 05-15-2019, 12:36 AM
hauss's Avatar
hauss hauss is offline
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
Default Rear adjustment
Originally Posted by bobcowan View Post
I'v driven my car about 1200 miles now. Still getting used to it. But I didn't think the car felt that precise. I had some time today to mess with it.
I raised the front ride height about 3/4". I managed to scrape the bottom of the scoop a couple of times.
Then I put it on the scales. This is the baseline.
I made a minor adjustment to the left front
This is with about 1/2 tank of fuel, and no weight in the driver's seat. Sometimes I'm in the car alone, and sometimes not.
Unfortunately, there is no adjustment for the rear, or I would have taken a little weight out of the right rear. If I was racing this car, I would make that adjustable.
I also checked the front end alignment. Caster and camber are fine. But it had 1/8" toe out. I changed that to 1/16" toe in.
Did it help? YES! A noticeable improvement in feel and ride. I like it.
Are you sure about no adjustment for the rear? My car does they are hard to get at had to remove the rear wheels to get at them.Should be at the top of the rear springs that is where mine are.
