Originally Posted by patrickt
Damn, that is ridiculously complicated. If you pull apart the 12 wire plug that connects the trailer/flasher contraption that we use, and then, with the plug completely apart, feed 12v+ to each of the eight hot feed wires that go to each corner bulb, can you get each corner bulb to light each of the two filaments (eight separate filaments in total)?
Patrickt -
You gave me a slap up side the head! Apparently that is what I needed. I started jumping 12vdc to each of the plug pins as you suggested. I got to the right front park/sig light and it didn't work when I jumped 12vdc to it. I was applying the 12vdc to the pin in plug #7. I looked further downstream and discovered a pin on #27 plug pushed back so that it wasn't making contact. With it pushed in properly every light on the car is working now. I guess I was making it too complicated. I will recheck it in the morning as I still can't believe it. Maybe I am in a dream right now.
THANKS!
BD
