  #46 (permalink)
Old 05-17-2019, 08:57 PM
ACHiPo's Avatar
ACHiPo ACHiPo is offline
Cobra Make, Engine: ERA 824 with 470 FE BBM street 427
I would guess that the short to ground is upstream on the Green line. Perhaps at the tach, or the wipers, or the wiper switch. Leave Fuse 3 out of the car entirely, check and replace any other fuses that may have blown, and start the car up again with the modification that you made to the VR at Bob's direction. Run the engine and check your system voltage with headlights on, etc., and see if you have a nice 13 or 14 volts, which would indicate that the system is charging normally.
The only fuse that blows is Fuse 3. I'm going to disconnect the tach. I don't know if I can get to the wiper switch or heater. I will check charging voltage assuming I can get things to run in Bob's configuration.
The system charged normally for about 60 seconds with Bob’s configuration. It doesn’t seem that charging happens with fuse 3 blown.
