Originally Posted by ACHiPo
Turns out the “short detector” is nothing more than a continuity tester. Guess what? There’s a short to ground at fuse 3. Who’d a thunk it?!
Grrrrr
If you have a compass and an automotive turn signal flasher unit you can make your own. That's all the fancy ones do (well, maybe a
little bit more sophisticated). They just send a signal through the line and then use a little receiver to pick up the signal. When the signal is no longer present in the line, you've found your short.
