Old 05-19-2019, 03:37 PM
hauss's Avatar
hauss hauss is offline
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
I have found with my transmision the tko 600 the only time I had a problem,was when the slave cylinder gave out . Shifting was never a issue for me. The 5th and reverse gear rail broke in two, causing it to be stuck in 5th gear.Hope this never happens again after I fix it. Tremec will not send parts to fix, so you are on your own, at least in my case.
