05-27-2019, 06:09 PM
CA
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
crank
what do you mean cranks 3 times? the motor turns over 3 times? If the car ran good before changing the rotor, it is probably something you did while removing the dist cap. Make sure your coil wire in pushed in all the way. Did you turn your distributor? is the hold down bolt loose?
