Thread: Map-able ECU
Old 06-01-2019, 06:10 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Unless you went with a really radical cam, the factory tune should be pretty close. If anything, it would run a little lean. You might have a different problem that can't be solved with a tune. Look for vacuum leaks, stuck injector, etc.
There are external performance "chips" available for your ECU. They can be tuned specifically for your engine.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
