Old 06-02-2019, 10:15 AM
eschaider's Avatar
Originally Posted by olddog View Post
MAF is a challenge with the 8 stack. You either have to use 8 MAFs (one for each stack) or you could try one MAF on one stack. I think the Megasquirt will certainly let you do one MAF on each side of the engine (total of two). I doubt it will support 8 MAF, but maybe so.
Or you could build a removable plenum to seal up to the 8 stacks and have one opening to pull air through and put a single MAF there. If so might as well pipe it to a cool air source while your at it.
You are right Olddog, brain fade, I wasn't thinking! The air box work would be prohibitive. This is an example of where speed density is a much better fit.
Ed
