Thread: Richmond OD
  #33 (permalink)
Old 06-05-2019, 03:35 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by cycleguy55 View Post
Does your shifter have steel or nylon bushings? Mine had the latter, and when they wear the shifter gets sloppy. Replace the bushings in the shifter and make sure it's adjusted properly. Use the Hurst Pit Pack with steel bushings. https://www.summitracing.com/int/par...7302/overview/
https://www.shifterdoc.com/productca...ngs-53p336.htm
Hurst owners's manual / instructions: https://www.shifterdoc.com/4070009_Install.PDF
Yes. Seems consistent with an alignment issue, either the shifter rods may need to be adjusted , or maybe there's an issue internally with the tranny, with the selector plates/detentes.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
