Thread: Map-able ECU
Old 06-07-2019, 04:41 PM
eschaider's Avatar
Joel's points are spot on sandpit. Chips were what was used before tuning s/w was generally available. A chip solution is half a kiss and a promise. If something goes bump in the dark and the chip programmer has managed to get a real job you are high and dry with no way to modify the code — and many times no way to even see what the chip modified in the code.
You need a modern EFI system that is self learning and modifiable by the owner or other individual willing to learn the system. The sweet siren song of the other alternatives will cost you dearly.
In Greek mythology. Sirens were beautiful half women with the upper bodies of humans and the lower bodies of birds. Their bewitching songs and unparalleled beauty would lure sailors to their doom. So irresistible were their songs that sailors who heard them would navigate their ships ever closer to the shoreline only to crash on the rocky bottom hidden just below the water's surface and drown.
You are hearing modern day Siren songs. The correct answer to your dilemma is a modern EFI system and get back into the deep water away from the rocky shore. I encourage you to look real hard at the MS3Pro ULTIMATE. Beware of the Sirens ...
Ed
