Originally Posted by A-Snake
Did you squeegee all the glass cleaner off after applying the decal? Use a credit card like a squeegee and run it over the decal to remove all bubbles.
They aren't using the adhesive versions. They're using the static cling versions. I suspect it is very hard to keep them on at speed, but the adhesive ones aren't hard to remove (you just tear them up doing so).
