Thread: Lights
Old 06-17-2019, 10:59 AM
patrickt patrickt is offline
Originally Posted by bobbybeige View Post
That's where I thought it would be, but I only saw a flasher relay there (3 pin) Did not see the headlight relay anywhere. Unless it's hidden behind the kick panel
Here's a pic of mine. Note the headlight relay at the top of the pic. It is zip tied to the steering column. The flasher unit is part of the trailer relay fusing set up. It all runs in to the same circuitry, so it's got to be around there somewhere. Try tracing the wires as you see them below. It's probably just hiding behind something.
